HDBT 3.0 CAT7 Ethernet Extender
$699.00
For technical support or questions regarding Level 1 Techs hardware, KVMs and their accessories that are not answered in the product description below, please submit a support ticket.
This little product is very unique! It is capable of sending an HDMI 2.0 4K 60Hz video signal through a SINGLE CAT6A or CAT7 cable.
The bi-directional HDMI signal enables local video out near the transmitter, or a remote signal near the receiver. This can be swapped through a button press.
Through the local/remote functionality, this product allows local users (close to the transmitter) to…
  • Monitor an HDMI signal from the receiver (like a security camera for instance)
  • Broadcast an HDMI signal to both the local user’s display and remote user’s display.
The audio is completely customizable with an embedder / extractor built in. Audio can be…
  • Independently transmit the signal from transmitter -> receiver
  • Embedded from a 3.5mm source to an HDMI signal
  • Extracted from HDMI audio to 3.5mm stereo. This option is especially helpful as it provides a second audio channel for an external sound configuration or amplifier.
Transmitter Inputs / Outputs:
  • CAT7 Ethernet OUT port
  • USB-B 2.0 IN
  • HDMI 2.0 IN (PC connection)
  • HDMI 2.0 OUT (local connection) e.g. monitor
  • Audio Embedding (green)
  • Audio OUT (red)
  • 3x USB 2.0 ports
  • Serial Extension port
Receiver Inputs / Outputs:
  • CAT7 Ethernet IN port
  • HDMI 2.0 IN (Reverse connection) e.g. camera
  • HDMI 2.0 OUT (Remote conneciton) e.g. monitor
  • Audio IN (red)
  • Audio De-Embedding (green)
  • 4x USB 2.0 ports
Quantity:
Add To Cart
  • USB-B 2.0 IN
  • Audio OUT (red)
  • 3x USB 2.0 ports
  • Audio IN (red)
  • 4x USB 2.0 ports
  • USB-B 2.0 IN
  • Audio OUT (red)
  • 3x USB 2.0 ports
  • Audio IN (red)
  • 4x USB 2.0 ports
Features:
- Allows Reliable Remote Access of a Computer or Video Source via a CAT.6A / 7 Cable Up to 90 Meters ( 295 feets )
- Uncompressed True 4K HDMI 2.0 Extension Enabled by HDBaseT 3.0 Technology
- HDMI 2.0 Video Supports Most Popular Resolutions Up to 4K@60Hz ( 4:4:4 ) and 8K@30Hz ( 4:2:0 )
- HDCP 2.2 and HDCP 1.4 Compliance
- HDR10 Support for Best Visual Experience
- USB 2.0 Extension Supports Keyboard, Mouse, USB Storage, USB Camera, and Other Devices
- Serial Extension Allows for Extensive RS232 Control Applications
- CEC Pass Through Allows Easy Control
- Audio Embed Allows User to Insert Informative Audio Content into The HDMI
- Audio Extract Allows Easy Connection to an Analog Audio Amplifier
- Audio Embed Controls at Both Sides Allows Practical Audio Applications
- ARC ( Audio Return Channel ) Facilitates Sound Bar Application
(B-STOCK) USB-C KVM Switch v2 (with USB Power Delivery / 70watts)
$320.00
Sold Out
Cisco-Compatible CAT6 RJ45 to RJ11 Adapter for HDMI 2.1 KVMs
$12.00
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer
$725.00
Sold Out
HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer
$500.00
Sold Out
4-Port KM Switch with USB SYNC, Serial Control, & Remote
$220.00
Sold Out
