KVM Switch | Rack Mount Kit
Rack mount kits for KVM Switches. These brackets will allow you to rack mount the Level 1 HDMI, 1.4 Displayport Single Monitor 4-Computer, 1.4 Displayport Dual Monitor 4-Computer KVM switches in a standard 19” rack. There isn’t much to them. They’re bits of metal.
Note: Not compatible with the USBc KVM or the 1.4 Displayport 2-computer KVM models.
Be aware: Dual monitor KVMs are a bit taller, and will take up more than 1 u of rack space.
Kit Includes:
2 Brackets
6 - 12mm (M5 x 0.8) bolts
8 - 8mm (M4 x 0.7) bolts
2 - 8mm (M3 x 0.5) bolts
For technical support or questions regarding Level 1 Techs hardware, KVMs and their accessories that are not answered in the product description below, please submit a support ticket.
Kit Includes:
2 Brackets
Kit Includes:
2 Brackets
