L1 | Decal
Plotted cut vinyl L1 decals. Available in two sizes, small and large. Purchase a 2-pack and save 25%. Great for PC cases, car windows, etc. Send us photos of yours and we might add it to the image gallery here.
Sizes:
Small - 1.6 in x 2 in (4 cm x 5 cm)
Large - 3.15 in x 4 in (8 cm x 10.2 cm)
Color: White
We can not refund you if you install your decal incorrectly. Take care and be sure you know what you are doing.
1. Peel the backing off the decal.
2. Apply the decal to a smooth clean surface.
3. Remove any air bubbles by applying pressure to the decal, pressing from the middle out to the edges.
4. Wait two minutes.
5. Peel away the face sheet carefully being sure to not peel up the decal at the same time.
There are good videos on You Tube showing how to apply cut vinyl decals successfully.
Sizes:
Color: White
Sizes:
Color: White
