Mouse Pad 40cm x 30cm x 3mm | Level 1 Warhol
This mat is 50% off due to some minor problems in the design. Some of the black dye migrated into some of the orange squares. In many cases the problem is barely noticeable. See the attached images.
Our Level 1 Warhol inspired design on a premium gaming mouse pad.
Made of 3mm supple rubber with gaming microfiber fabric and braided edges.
Dimensions: 15.75 inches wide X 11.75 inches tall X 0.125 inches thick (40 cm X 30 cm X 3 mm)
Shipping Weight: 0.9 pounds
Washing Instructions: Machine was, cold water, gentle cycle. Tumble dry low heat. Do not over dry. Wash only when needed. Repeated washing is not recommended.
