Skip to Content
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Products
Level 1 Techs
Store Info
Login Account
Products 4-Port KM Switch with USB SYNC, Serial Control, & Remote
1 / 5
4Port-USB-SYNC-1.jpg Image 1 of 5
new usb km.png Image 2 of 5
4Port-USB-SYNC-3.jpg Image 3 of 5
KVM-adapters.jpg Image 4 of 5
differences final.png Image 5 of 5
$250.00
SYNC MODE
This feature simultaneously sends cursor movement, commands, and keyboard input to ALL connecting 4 identical hardware computers.
Serial Port
A unique tracking system enables the USB devices to be operated independently or concurrently. For example, USB tracking function allows USB switch (KM Switch) users to decide whether or not the USB devices (USB Flash Drive, Printer, and Scanner) switching follows the PC ports switching.
Ethernet Port Exception
Our KVM / KMs usually do not offer an Ethernet port, however, we’ve realized that having Ethernet active on only the selected port via USB is not optimal for this product. This KM does offer an Ethernet port for those who want it, but we still advise the use of a network switch for most applications.
Connections:
Front
  • USB 3.2 Gen 1 Type A x1
Rear
Inputs
  • 4x USB 3.2 Gen 1 Type B
  • 4x 3.5mm Audio in
  • 1x USB Audio Analog in
Outputs
  • 3x USB Type A
  • 1x USB 3.2 Gen 1 Type A
  • 1x 3.5mm Audio out
  • 1x GbE LAN RJ45
For technical support or questions regarding KVMs and their accessories that are not answered in the product description, please submit a support ticket.
Quantity:
Add To Cart
SYNC MODE
Serial Port
Connections:
Front
Rear
Inputs
  • 4x 3.5mm Audio in
Outputs
  • 3x USB Type A
  • 1x GbE LAN RJ45
USB-C to USB-C Cable - Black | 39 Inches (100 cm)
$13.00
USB 3.0 Super Speed A to B Cables | 6 Foot (180 cm)
$7.00
Signature Required Upon Delivery
$9.99
SYNC MODE
Serial Port
Connections:
Front
Rear
Inputs
  • 4x 3.5mm Audio in
Outputs
  • 3x USB Type A
  • 1x GbE LAN RJ45
Features:
  • Mouse Roaming Allows Seamless Switching among PCs by Moving the Cursor across the Screen Borders and Circulating among PCs Flexible Monitor Layouts Include : 4x1, 2x2, 1+3, 1x4, 1+2, 1+3
  • Mouse Control Allows Switching among PCs by the Mouse Buttons & the Mouse Wheel
  • Serial Control Allows Controlling Remotely or Incorporation with Central Control System
  • USB Broadcast ( Synchronizer ) Allows Users to Duplicate USB KB/MS Signals to All PCs
  • Panel Lock Prevents Accidental Button Clicking
  • Hard Hotkey Allows Users to Trigger Hotkey Control by Pressing & Holding Front Push Button
  • Mask Hotkey Allows Users to Forbid Triggering Hotkey Control by Keyboard
  • LAN Sharing Port Facilitates IP Scanner /Printer / Camera Applications
  • Audio / USB 3.2 / LAN Independent Switching Allows the Console's Audio / USB 3.2 / LAN Ports to Either Follow the Main Control or Stick to a PC
Important Usage Information:
  • Corsair keyboards are currently unable to use KVM or KM hotkeys when plugged into HID ports.
You Might Also Like
Cisco-Compatible CAT6 RJ45 to RJ11 Adapter for HDMI 2.1 KVMs
$12.00
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer hdmi 4x2.png HDMI-EDID-4C2M-3.jpg KVM-adapters.jpg differences final.png
$840.00
Sold Out
HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer hdmi 4x1.png HDMI-EDID-4C1M-3.jpg KVM-adapters.jpg differences final.png
$575.00
Sold Out
HDMI EDID Modifier / Rewriter
$99.00
EDID Feeder - HDMI 2.1 / DisplayPort 2.0 side 1.png side 1.png top.png
from $225.00
