Skip to Content
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Products
Level 1 Techs
Store Info
Login Account
Products HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer
HDMI-EDID-4C1M-1.jpg Image 1 of 5
hdmi 4x1.png Image 2 of 5
HDMI-EDID-4C1M-3.jpg Image 3 of 5
KVM-adapters.jpg Image 4 of 5
differences final.png Image 5 of 5
$575.00
Sold Out
For technical support or questions regarding Level 1 Techs hardware, KVMs and their accessories that are not answered in the product description below, please submit a support ticket.
Description
L1Techs HDMI 2.1 KVMs are here!
These KVMs are capable of monitor emulation (EDID), Serial console connection/hotkeys, variable refresh rate compatibility, and embedded audio/extraction!
Serial Console
The Serial Port (RJ-11 to RS-232 Adapter required) supports various Baud-rates of 9,600~115,200 (8 Baud-rates Selectable) and can control the KVM through shortcuts.
Audio Embedder & Audio Extractor
This feature embeds 3.5mm analog audio and converts it to an HDMI signal. Deembedding is when the HDMI audio is converted to 3.5mm analog.
The KVM has a tracking system that allows USB / 3.5mm audio to be tracked independently. For example, you could be working on a computer and hear all the system sounds, then be listening to music on another.
HDCP Management Slider
  • Mode-1: Auto mode allows HDCP 2.2 or HDCP 1.4 content pass-thru
  • Mode-2: NONE mode allows non-HDCP content to be played
  • Mode-3: HDCP 1.4 mode allows HDCP 1.4 content to be licensed
  • Mode-4: HDCP 2.2 mode allows HDCP 2.2 content to be licensed
Connections
Front
Output
1x USB HID Type A
1x USB 3.2 Gen 2 Type A
Rear
Input
4x HDMI 2.1
4x USB 3.2 Gen 2 Type C
4x Audio Jack (In)
1x Audio Jack (Embed) (HDMI)
Output
1x HDMI 2.1
3x USB HID Type A
4x Audio Jack (In)
1x Audio Jack (Extract) (HDMI)
Video Resolution (Max.)
  • 7680x4320@60Hz ( 4:4:4 )
  • 5120 x 2880 @ 60Hz (4:4:4)
  • 5120 x 1440 @ 120Hz (4:4:4)
  • 3840 x 2160 @ 144Hz (4:4:4)
  • 3840 x 2160 @ 120Hz (4:4:4)
Get notified by email when this product is in stock.
Add To Cart
Description
Serial Console
Connections
Front
Output
1x USB HID Type A
Rear
Input
4x HDMI 2.1
4x Audio Jack (In)
Output
1x HDMI 2.1
3x USB HID Type A
4x Audio Jack (In)
HDMI Cable | 79 inch (200 cm)
$17.00
USB-C to USB-C Cable - Black | 39 Inches (100 cm)
$13.00
Cisco-Compatible CAT6 RJ45 to RJ11 Adapter for HDMI 2.1 KVMs
$12.00
Signature Required Upon Delivery
$9.99
Description
Serial Console
Connections
Front
Output
1x USB HID Type A
Rear
Input
4x HDMI 2.1
4x Audio Jack (In)
Output
1x HDMI 2.1
3x USB HID Type A
4x Audio Jack (In)
Features:
  • Supported upto HDMI 2.1 Up to 8K@60Hz
  • HDR / DSC / VRR Support for Best Visual Experience
  • HDCP 2.2 / 1.4 Compliance Ensures Uninterrupted Video Playback
  • HDCP Engine Ensures Low-Latency Switching
  • HDCP Management Allows Selection of Proper HDCP Version
  • EDID Management, Including HDMI 2.1 ( FRL ) & HDMI 2.0 ( TMDS ) EDIDs, Ensures Display Compatibility
  • Audio Embed/Extract Allows User to Insert External Audio into the HDMI Audio Stream
  • Front USB Allows Easy Access
  • Plug-and-Play without Software or Driver
  • 10Gbps USB 3.2 Sharing Provides Excellent Speed
You Might Also Like
$12.00
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer hdmi 4x2.png HDMI-EDID-4C2M-3.jpg KVM-adapters.jpg differences final.png
$840.00
Sold Out
4-Port KM Switch with USB SYNC, Serial Control, & Remote new usb km.png 4Port-USB-SYNC-3.jpg KVM-adapters.jpg differences final.png
$250.00
HDMI EDID Modifier / Rewriter
$99.00
EDID Feeder - HDMI 2.1 / DisplayPort 2.0 side 1.png side 1.png top.png
from $225.00
