Skip to Content
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Products
Level 1 Techs
Store Info
Login Account
Products HDMI EDID Modifier / Rewriter
top.png Image 1 of 4
side 2.png Image 2 of 4
side 3.png Image 3 of 4
side 1.png Image 4 of 4
$99.00
For technical support or questions regarding Level 1 Techs hardware, KVMs and their accessories that are not answered in the product description below, please submit a support ticket.
Rewrite the EDID To Fix Bugs -- up to 1920x1080, 2048x1536
BEFORE YOU BUY!
This product is REALLY special. If you're here, something has gone wrong. Email wendell @ level1techs.com if you think you need this so we can discuss. This is used to make older, but still awesome, 1080P CRT projectors work with more modern 1080p HDMI sources.
This can be used to solve certain unsolvable issues with projectors, televisions and home theatre A/V equipment (only up to 1080p though).
It does this by allowing you to modify the EDID and upload the modified EDID or pre-copied EDID data to your displays, ie write the copied or presetting EDID to the display device. Users may either merely write Audio EDID or upload both Audio and Video EDID for multimedia system integration.
Features:
  • EDID learning (read / store) functions prevent computers from deactivating inactive HDMI ports
  • Unique Audio Inventory features provide 2ch. / 5.1ch. / 7.1ch. Audio EDID learning, best for Home Theater system application
  • Innovative technology to integrate emulated EDID parameters and display’s HDCP parameters
  • The Rotary Switch is provided to manually select video resolutions
  • 3 modes for different applications: PC Mode, AV Mode, and Memory Mode:
  • PC Mode- for desktop and laptop system
  • AV Mode- for Home Theater AV application
  • Memory Mode- Reserve EDID information of your video/audio system
  • Professional AV performance configuration, like distinctive 50Hz / 60 Hz of frame rate and interlaced/progressive (non-interlaced) scanning system.
EDID Ghost (DDC Ghost)
  • Read and store (record) the EDID from the connecting display to the video extension system
  • Tremendous system for different types of incoming EDID data reading
  • Up to 15 presets/records of EDID data can be stored
EDID Emulation
  • Emulating EDID information ensures displaying the optimum video resolution
  • Provide EDID data, if a display's EDID is not available
  • Alternatively, perform the default or the copied EDID for the connected display device
  • Selectable EDID functions for multimedia system integration
  • Support DVI signal
  • Selectable scan mode and frame rate combined with optional video resolution for flexible and utmost uses of your displays
EDID Writing
  • Upload the EDID to the connected video display
  • Write the copied or presetting EDID (default EDID) to the video extension system
Quantity:
Add To Cart
BEFORE YOU BUY!
Features:
EDID Emulation
EDID Writing
Signature Required Upon Delivery
$9.99
HDMI Cable | 79 inch (200 cm)
$17.00
BEFORE YOU BUY!
Features:
EDID Emulation
EDID Writing
Specification
MAX Video Resolution
Input Port
2048 x 1152 or 1920 x 1080
HDMI x1
You Might Also Like
Cisco-Compatible CAT6 RJ45 to RJ11 Adapter for HDMI 2.1 KVMs
$12.00
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer hdmi 4x2.png HDMI-EDID-4C2M-3.jpg KVM-adapters.jpg differences final.png
$840.00
Sold Out
HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer hdmi 4x1.png HDMI-EDID-4C1M-3.jpg KVM-adapters.jpg differences final.png
$575.00
Sold Out
4-Port KM Switch with USB SYNC, Serial Control, & Remote new usb km.png 4Port-USB-SYNC-3.jpg KVM-adapters.jpg differences final.png
$250.00
EDID Feeder - HDMI 2.1 / DisplayPort 2.0 side 1.png side 1.png top.png
from $225.00
