Skip to Content
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Products
Level 1 Techs
Store Info
Login Account
Products 4-Port KM Switch with USB 3.2 Gen 1 Mouse Roaming Function
1 / 4
4pc km front.png Image 1 of 4
4pc km ana.png Image 2 of 4
4pc km 5gb.png Image 3 of 4
differences final.png Image 4 of 4
$230.00
BEFORE YOU BUY!
If you intend to use mouse roam please use with only a single display (real or virtual) per input. Microsoft has disabled the ability to use more than one absolute co-ordinate pointing device in some Windows updates.
This device is lower cost than a full KVM, but gives you the ability to switch inputs by key switch, shortcut key or based on absolute mouse co-ordinate (for fully HID-compliant USB mice only)
This switch is pure hardware design, built-in 4 preset screen layout, no software or driver required, compatible with Windows and Mac system.
  • Allow 4 Computers to share USB peripherals ( USB HID x 3 + USB 3.2 Gen 1 x 2 )
  • Mouse Roaming functionality makes perfect operation experience by simply moving the mouse cursor across screen border selecting the previous /next PC
  • Flexible Preset Screen Layout of 1 x 4, 2 x 2, 1 + 3 or 4 x 1.
  • Mouse Absolute Coordinate Technology enables seamless switch among PCs and adapts to all kinds of mouse sensitivity
Optional:
  • Support USB Audio: This version of the device supports audio functions with a basic built-in audio endpoint for each KM input on the switch. The rear I/O changes a bit and includes analog audio out. The basic version is only analog ports, USB audio is essentially an internal USB audio DAC which makes the cabling a little cleaner and is higher quality than analog audio.
For technical support or questions regarding KVMs and their accessories that are not answered in the product description, please submit a support ticket.
Audio Interface:
Quantity:
Get notified by email when this product is in stock.
Add To Cart
BEFORE YOU BUY!
Optional:
USB 3.0 Super Speed A to B Cables | 6 Foot (180 cm)
$7.00
USB-C to USB-C Cable - Black | 39 Inches (100 cm)
$13.00
Signature Required Upon Delivery
$9.99
BEFORE YOU BUY!
Optional:
Why Our KVM Switches Don’t Include an Ethernet Port
We often get asked why our KVM (Keyboard, Video, Mouse) switches don’t come with an Ethernet port. It’s a great question — and the answer has everything to do with keeping your network stable and your devices protected.
Our KVM switches are designed to cleanly switch control of your keyboard, video, and mouse — but networking is a different story. If we were to add an Ethernet port and try to switch it between devices, we’d essentially be reinventing something that already exists: a network switch.
Network switches are made to manage multiple devices on a shared network reliably and simultaneously. They handle traffic differently and are designed for constant connectivity — not for quick, manual switching like a KVM. Combining these two roles could lead to unnecessary complexity and reliability issues.
In short, we believe in using the right tool for the job. That’s why we leave networking to the dedicated Ethernet switches — and focus on building rock-solid KVMs that do their job well.
Check out our KVM FAQ!
You Might Also Like
Cisco-Compatible CAT6 RJ45 to RJ11 Adapter for HDMI 2.1 KVMs
$12.00
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer hdmi 4x2.png HDMI-EDID-4C2M-3.jpg KVM-adapters.jpg differences final.png
$840.00
Sold Out
HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer hdmi 4x1.png HDMI-EDID-4C1M-3.jpg KVM-adapters.jpg differences final.png
$575.00
Sold Out
4-Port KM Switch with USB SYNC, Serial Control, & Remote new usb km.png 4Port-USB-SYNC-3.jpg KVM-adapters.jpg differences final.png
$250.00
HDMI EDID Modifier / Rewriter
$99.00
