Skip to Content
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Products
Level 1 Techs
Store Info
Login Account
Products Display Port 1.4 Cables | 200 cm
cable-120cm.jpg Image 1 of 4
cable-200cm.jpg Image 2 of 4
cable-end1.jpg Image 3 of 4
cable-end2.jpg Image 4 of 4
$15.00
Also available in 120 cm (47.25 inches) length.
Reasonable DisplayPort 1.4 cables for a reasonable price? I'm not going to say they are absolutely perfect but they cost a bit less than the Club3d Cables (which are for sure better than these).
I have been using this cable with my particularly-picky Acer CG9 and the Level1Techs DP1.4 KVM and it works reasonably well. Remember to try to keep your total cable length as close to or under 2 meters as possible. These cables are good quality 19-pin DP cables and are ideal for the Level1techs KVM.
For technical support or questions regarding KVMs and their accessories that are not answered in the product description below, please submit a support ticket.
Quantity:
Add To Cart
USB 3.0 Super Speed A to B Cables | 6 Foot (180 cm)
$7.00
USB-C to USB-C Cable - Black | 39 Inches (100 cm)
$13.00
You Might Also Like
Cisco-Compatible CAT6 RJ45 to RJ11 Adapter for HDMI 2.1 KVMs
$12.00
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer hdmi 4x2.png HDMI-EDID-4C2M-3.jpg KVM-adapters.jpg differences final.png
$840.00
Sold Out
HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer hdmi 4x1.png HDMI-EDID-4C1M-3.jpg KVM-adapters.jpg differences final.png
$575.00
Sold Out
4-Port KM Switch with USB SYNC, Serial Control, & Remote new usb km.png 4Port-USB-SYNC-3.jpg KVM-adapters.jpg differences final.png
$250.00
HDMI EDID Modifier / Rewriter
$99.00
