Skip to Content
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Level1Techs Store
Products
Level 1 Techs
Store Info
Login Account
0
0
Products
Level 1 Techs
Store Info
Login Account
Products USB-C Combiner: DisplayPort and USB to USB-C
MicrosoftTeams-image+%2827%29.png Image 1 of 5
MicrosoftTeams-image+%2828%29.png Image 2 of 5
MicrosoftTeams-image+%2829%29.png Image 3 of 5
combo with combiner.png Image 4 of 5
USBC with Combiner.png Image 5 of 5
$99.00
For technical support or questions regarding Level 1 Techs hardware, KVMs and their accessories that are not answered in the product description below, please submit a support ticket.
This item will take a DisplayPort 1.4 + USB5gbps input and convert it to USB-C output.
The significance of this is to make USB-C KVMs possible for more people who want them, but have a computer that does not support both display and usb signals on the usbc connector.
If you want to use a MAC + PC, typically you would have to use a DisplayPort KVM & convert the USB-C device output to DisplayPort. Cables like the Moshi USB-C to DisplayPort cable cannot be flipped around to be a DisplayPort PC output to USB-C KVM input. Therefore, if you want to use the Level1Techs USB-C KVM with a DisplayPort device, the best solution we offer is the USB-C Combiner.
NOTE: this does mean that the display and usb share bandwidth. Don't expect 4k/120hz and 5gbps usb at the same time. You need display stream compression (generally not a good time on mac) or to run the usb in usb2 mode at these extreme dp bandwidths.
https://www.youtube.com/watch?v=D4mp60rp60E
Please note that the label and the manual incorrectly refer to DisplayPort 1.2. The unit is DisplayPort 1.4 compatible. The label and manual are incorrect.
Quantity:
Add To Cart
USB-C to USB-C Cable - Black | 39 Inches (100 cm)
$13.00
USB 3.0 Super Speed A to B Cables | 6 Foot (180 cm)
$7.00
Signature Required Upon Delivery
$9.99
Check out our KVM FAQ!
You Might Also Like
Cisco-Compatible CAT6 RJ45 to RJ11 Adapter for HDMI 2.1 KVMs
$12.00
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer hdmi 4x2.png HDMI-EDID-4C2M-3.jpg KVM-adapters.jpg differences final.png
$840.00
Sold Out
HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer hdmi 4x1.png HDMI-EDID-4C1M-3.jpg KVM-adapters.jpg differences final.png
$575.00
Sold Out
4-Port KM Switch with USB SYNC, Serial Control, & Remote new usb km.png 4Port-USB-SYNC-3.jpg KVM-adapters.jpg differences final.png
$250.00
HDMI EDID Modifier / Rewriter
$99.00
